DAB+ Capability
Jkh112
Bristol, UK
E350 Bluetec estate
Talkradio is moving from DAB to DAB+.
I looked online and was disappointed to find that my 2014 E350 should not be capable of receiving DAB+.
However the car finds and receives the new Talkradio+ channel on DAB+.
About 3 years ago I had the DAB aerial booster replaced under warranty due to poor reception so has this given me access to DAB+ or has my car has always had the capability to receive DAB+?
Botus
S500/2010/500
its a tuner thing, similar issue to MPEG2 compression vs MP4, similar quality twice the data on the earlier codec - that ability to cope is wrapped up in the chipset of the tuner
they are probably still broadcasting both … but for how long?
Jkh112
Jkh112
Bristol, UK
E350 Bluetec estate
Talkradio stop broadcasting both on Monday.
Botus
S500/2010/500
the sick thing is some tuners could cope with a firmware update in 2007...
which would suggest Mercedes are just budget rubbish, using cheap old parts without any consideration toward customer satisfaction or environmental sustainability
Jkh112
Jkh112
Bristol, UK
E350 Bluetec estate
If that is true then how am I receiving in my 2014 car?
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
I have a 2016 E350 with NTG5.2 and don’t believe I can receive DAB+
unless I’m doing something wrong of course.
Hopefully there is some upgrade I can do other than replace command of course.
Robin
Jkh112
Jkh112
Bristol, UK
E350 Bluetec estate
That is why I am confused (but pleased) that my car does seem able to pick it up. Very odd.
flowrider
SL500 (R230)
In my SL I have a Nextbase adapter that receives DAB and DAB+, it only cost £32.
Likewise, although mine was £17 :)
(Everything is cheaper in an SLK):p:D
Srdl
Hampshire
GLC43 AMG 2018 (X253)
I suspect an upgrade of some sort was done when you had the warranty work done.
Example here
Jkh112
Jkh112
Bristol, UK
E350 Bluetec estate
That is what I suspect too. I know they did a software update and said they fitted a new dab aerial booster but the work could have given me DAB+as an additional benefit.
Botus
S500/2010/500
Example here
that article says you BUY a new DAB+ receiver
Thanks to the excellent performance of the DAB + tuner, whose function has been optimized especially for retrofittable Mercedes-Benz vehicles, the optimal DAB + sound is available in the vehicle even with reduced digital reception. The conversion solution is available for CHF 219 (recommended retail price, excluding VAT plus installation) (pd / ml)
www.mercedes-benz.ch
