DAB Radio Question
Keith Tudball
Registered
E300 Est
I was wondering if there is a fix to get better reception on a Merc radio as it cuts out all the time!
Any answers will be appreciated!
Botus
S500/2010/500
use the search feature.
http://forums.mercedesclub.org.uk/index.php?threads/command-online-dab-intermittent-signal.162909/
yes across many models there are both software updates and in some case physical antenna /antenna amp replacements that should be done under warranty.
however you need to push hard to get this done, they'll likely throw a software update at it and tell you to go away, when without them doing both elements its almost not worth the effort
and even if they do everything u must remember the fix will likely go from 100% useless to only 50% better
