Difference between c200CDI and C220 CDI ?
Muppet2002
I've searched, but not found an answer here so...
Can anyone tell me the difference between the C200 CDI and C220 CDI engines ? (W203) other than the ECU mapping.
Thanks !
psmart
The 200CDI engine was typically created for Tax purposes here in Germany. I havent personally looked at them, but spoken several times with Taxi Drivers who tend to buy the E200cdi as its much cheaper, then change the injectors and ECU. From what they describe, the two engines are physically identical.
If you have the time, study the C200 engine at http://www.detali.ru/cat/oem_mb1.asp?TP=1&F=203004&VIN=
and the C220 engine at
http://www.detali.ru/cat/oem_mb1.asp?TP=1&F=203006&VIN=
If 2003.004 isnt your engine, then start at:
http://www.detali.ru/cat/oem_mb0.asp?TP=1
Compare part numbers on key components, such as injectors, turbo-charger etc to give an idea about what differs.
Muppet2002
It was my suspiscion that both engines were near identical, but with different ECU maps - but you guys seem to be suggesting that the injectors are also different ?
I wonder if there is a company in the UK who will upgrade the injectors and ECU and how much that would cost.... ?
