Differential oil for Viano Compact 3.0 Cdi.
Droverunner
West Cambridgeshire
As part of a gradual mid life all items service I want to change the differential oil. Is there a source of definitive Mercedes info for the 100% correct oil. Running my reg no. Opie come up with Febi 48785 75W-85 GL5 and I can see Fuchs do a Titan Sintopoid 75W-85 GL5. But I would like to see the Mercedes part or spec no. to be sure.
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
The Mercedes spec for it is 235.7 and the Mercedes part number is P/N 001 989 33 03
We have the Febi 75w-85 and as you say also the Fuchs Sintopoid 75w-85 that both meet that spec and ideal.
Cheers,
Guy
M80
Derbyshire
The Titan was my choice
Droverunner
Droverunner
West Cambridgeshire
Appreciate the confirmation from Guy. I like Fuchs too... for no reason I can explain. I'll get it ordered from Opie.
Droverunner
Droverunner
West Cambridgeshire
Ordered from Opie now, funnily enough just noticed I have .75l left on the shelf from a gearbox change on my previous BMW.
Just for the chat... I'd read an article that commented Sprinters could benefit from a heavier oil than the same spec as above because the "gearbox" grade oil was really only in axles for fuel saving but not the best for noise/longevity of a diff??
M80
Derbyshire
I'don't imagine 639 taxis with mega miles have 'upgraded'.
I would have thought they would just run on factory spec oil.
Droverunner
Droverunner
West Cambridgeshire
Yes I guess so and probably never topped up or changed.
steveq
Dublin
I understood that the Fuchs "Sintopoid" is for the hypoid gear rear axles and the "Sintofluid" oil is for manual gearboxes.
I don't think they are interchangeable.
Droverunner
Droverunner
West Cambridgeshire
Yes understood... I was really making a generic comment as if the 75w-85 oils were a lighter type often seen in gearboxes whereas years ago you would often see a straight 90 grade in a diff. The article I read said were it not for the economy factor 85w-140 was a better Sprinter diff oil.
steveq
Dublin
All oils seem to be lighter now.
I know that lighter oils = less drag = better economy.
I presume (hope) that the oil technology has developed to ensure that the lubrication qualities have been maintained or improved.
M80
Derbyshire
When I was looking for the correct diff oil i remember reading from one Vito owner who had been through 2 or 3 diffs.
He was of the opinion that MB used a too light oil for economy so he opted for heavier. But he was going through diffs at a rate I find very surprising.
I'll be changing the diff oil in the Viano soon(ish). It'll be the Fuchs Sintopoid as post 3.
My usage is light anyway.
It's a cheap oil change for peace of mind.
steveq
Dublin
I wonder what the Vito owner was carrying? If he was regularly carrying a couple of tons of concrete in the back it might be understandable!!
I have changed the diff oil in all my Mercs -- more for peace of mind than any tangible benefit.
MB only include it as a service item in the limited slip diffs in the real AMG models.
I also changed the manual gearbox oil in my C Class -- again, it's not an MB service item.
I did think the gear change was a bit smoother after that but it could just have been in my mind -- much the same as the car always runs better after a wash and wax!!
Droverunner
Droverunner
West Cambridgeshire
As usual great service from Opie with prompt delivery. Old oil was free of contamination and just a bit darker than the new.
Nice easy job with all the room under a Viano. Often with a car there can be problems with enough room to raise the oil bottle enough to drain so it's a squeeze it job. But on this vehicle there is room to lift the bottle to drain fully by gravity.
Another job of its 9yr / 60k mid-life check over completed.
