Double glazing problem - has anyone ever seen this?
amwebby
Thorpe Bay
W215
I'm hoping there is an inexpensive, or warranty cover, remedy for this.
it looks as though damp or water has gone between the laminations, used to see it years age, but you cant have it with toughened glass.
Malcolm
stumpy
various
I have this on my BMW windscreen. It is not covered by their warranty though. Maybe MB is different but I doubt it. My only option is a 50 quid excess windscreen change. Do you have glass cover on your policy?
amwebby
amwebby
Thorpe Bay
W215
I have glass cover, not sure it covers this.
The Hooded Claw
It does when you get hit by that nasty stone thats just sitting in yer drive ..........Oh hang a mo ....."In yer drive" won't work it's private property ......It was when you were following that local council truck it happened !!!!!!!!!
Sprint'n'Go
Ashton-under-Lyne, Near Manchester
They will cover broken glass. You just have to make sure its broken before you call them:rolleyes:
I have read elsewhere on this forum that some insurers will cover failed lamination. A sensible policy as they know otherwise it will just lead to deceipt/fraud.
The only snag is have you ever tried to break laminated side windows.
Malcolm
The Hooded Claw
14LBS Lump hammer & an old Phillips screwy................ comes out lookin just like a stone chip !!!
Automatic centre punch...
If you see cars with the white in the corner of the windscreen then as likely as not there will be serious corrosion hidden behind the windscreen surround.
I was only after a 'stone chip' crack, just enough to have the window replaced...;-)
