400ixl
- Feb 21, 2016
- Location
- UK
- E250 AMG Sport Convertible
It could be the soot content is just to high to do a regen, start with the cheapest option first, find your dpf sensor (probably on the rear of your airbox) and buy 1 can of dpf cleaner it comes with a line attached to go down the fat dpf pipe. follow the instructions on the can , its an aerosol and literally is a 5 minute job. take for a good run at 2-2.5 rpm . then get the light turned off mine went off on its own after a few more start ups.
It is the MAF/MAP sensor which is in the air system, not the DPF sensor which is in the exhaust.
Whoever switched off the light should also be able to readt the basic code. Assuming they used something like Torque on an Android phone and a bluetooth ODB reader. This can read codes as well, but not always to the deep level.
The EML will come on again when it is triggered. For example if it is the Exhaust temperature sensor then you can reset it and it will only come on again when the car does more than 1500RPM and 10mph. On tickover or stationary it wouldn't come back on.
Likewise, LIMP mode only activates after certain conditions are met. for example when a regen is required, but something is stopping it from being able to. As a regen would not be activated until up to a certain temperature, the LIMP mode won't kick in until then.
