E220d S213 engineclight on intermittent
Zululander
Essex -UK
E220D AMG line premium
Good to be back on the forum after a couple of years absent (not because of car brand change). I have this engine light coming on intermittent, when the car is cold all good and can be driven normally, temp registered 90c but when reaching r this temp and I switch off engine and restart, it will take about 1-2 minutes and the light is back on. Coll down and restart no light and the cycle starts again. Any advise please?
AMGeed
Poole, Dorset
S204 C180K
The normal culprit when a hot engine only restarts after cooling down is the crank position sensor (CPS).
I must admit I've had two Mercedes that have had a CPS issue and neither time did the check engine light come on.
Sounds like the car needs a diagnostic check with a Mercedes specialist with Star to diagnose the issue.
Zululander
Zululander
Essex -UK
The engine starts and dives normally, the issue is when hot management light pops up as soon as parked for a while and cools back down, the light is off until the temperature raises again to around 80 - 90c. I had a diagnostic done ( pics attached) although a 2018 model the car has only clocked 28000 miles
ajlsl600
france
I hav some experience of faulty cps stopping restarts intermittently but not stopping a running motor. On some motors there are 2 cps.
Zululander
Zululander
Essex -UK
Thanks guys for your input.
The issue has been tracked down to the addblue tank and pump. Expensive repair on the way
w213probs
w213 e220d
so what did you do then? the whole tank replace?
mioba
Nottingham and Köln
not uncommon and a well known failing of MB. There was a mention of it being cussed by crystals forming in the adblue, a solution was some kind of crystal diluent. No idea if that worked.
I do wonder if other car brands have the same problem.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
It doesn’t help that OP’s car has only done 28k miles since 2018 so not surprising that AdBlue is getting clogged up.
w213probs
w213 e220d
Adblue system needs a lot research i think. It works, its just about taking care of it and knowing what can go wrong eg crystallisation, ecu fault, poor adblue quality, additive to prevent crystals and etc.
Im loving my journey of adblue scr system learning. Have a whole thread on it
Srdl
Hampshire
Adblue system needs a lot research i think. It works, it’s just about taking care of it and knowing what can go wrong eg crystallisation, ecu fault, poor adblue quality, additive to prevent crystals and etc.
But no one tells you that when you buy a Euro 6 diesel!
malcolm E53 AMG
Best advice is don't buy a Euro 6 diesel (avoiding Euro 5 is also sensible)
Totally agree except that managed properly the EU5 diesel doesn’t cause too much trouble as long as you don’t use it as a shopping trolley - many were mis-sold unfortunately as were EU6 diesels. My son’s W213 covered 12-15k miles Pa over 75k miles without a hint of an ADBLUE problem that’s exactly the type of usage these vehicles require.
w213probs
w213 e220d
get your point and things. but i am really enjoying the journey of learning more about the SCR system. really nice.
Moved on from fixing the adblue pump myself to now looking at diagnostic systems. got the icarsoft v3. didn't like it. now looking for better tools which can help me do the actuation tests and etc.
www.ckinsurance.co.uk
