e280 battery
robparker
Taunton
I have just bought a '94 E280 and even though it starts right up the engine has been turning over a little slow and today i twice turned the key with nothing happening and the 3rd time it turned over slowly and fired up. Im assuming a battery issue... i have a spare battery that was fitted to my old 190d 2.5 in good condition, would it be ok to put this on? probably a stupid question...
BlackC55
South coast
C43
Should be ok if it is the same specifiaction and is fully charged. Check if it is.
Would it not be best to fit a new battery with a warranty that you know is good.
robparker
robparker
Taunton
Well knowing nothing about batteries the numbers on the 190 battery are less than the one currently on my car, i just firgured being fitted to a diesel it should have enough grunt for the 280. Just wanted to try fitting this one first, if it would fit, before spending money on a new battery
robparker
robparker
Taunton
e280- E11 12v 74AH 680A
190d- 067 63AH 600 SAE
thanks for your help.
BlackC55
South coast
C43
The 190 one is not suitable. The AH is too low.
Get a 74AH from a factors. They are only cheap and they are guarenteed too.
Hope this helps
robparker
robparker
Taunton
Ok will do. thankyou for the advice.
If the battery is good,it will do for now, in the summer months, A diesel normally has a high output battery. A fully charge small one is better than a ½ charged big one
