GJL69
- Jan 7, 2024
- Mercedes E300 Bluetec SE Hybrid 2.1 automatic estate
Hi All,
I'm new to the forum, but very keen on getting help with my E300 Hybrid 7G gearbox. Originally the car brokedown with RED transmission issue stop, error codes related to the solinoids. Car was recovered, gearbox serviced and was ok, but not 100%, car seemed to be slow pulling away or a hard acceleration in lowest gears would result in loss of all gears. If I turned the car off, wait and restart it would work again. Car want back into the garage and I was told it needed a new gearbox. I wasn't convinced so sent it to Mercedes to confirm, result was the same. Went on to change electric pack, valve body etc to try and avoid cganging the gearbox, but still no good. Finally changed the gearbox for a used one and still have problems. The garage are telling me that the issue is something stopping the automatic setup of the gearbox adaptions. Furthermore, when they changed the electric pack they failed to keep a copy of the old settings. Now they can't even put it pack to its original condition. Currently the car will drive after resetting the adaptions, but only for about 10 minutes, then it's like driving a car with a severely slipping clutch. Nightmere!
Has anybody got any advice, ideas or hopefully a cure? If anyone can share the transmission settings so I can ask the garage to manually enter them might work. I don't think the garage really know how to fix it, latest advice is the change the solinoids, but I'm not convinced.
Hope someone can help end this nightmere for me?
