littlewimp
- Feb 28, 2015
- Age
- 58
- Location
- gloucestershire
- E 55 Amg
Hi All, Im looking for advise on the Great airmatic Suspension! I've been having issues with the Usual rear left Dropping, i did have a Month between it dropping when i never had any issues, ive had it inspected for leaks on a 2 post ramp with the bags fully extended several times without finding anything, also the control valve at the Front has also been checked and nothing, i presume that there must be check valves fitted to the rear air pipes as i seems from the schematic to have just the one feed to the rear that splits to left and right, im just curious to know if there's anything else in the System connected to the Rear Bags that could cause it to loose Pressure, also can someone explain what happens to the System when im selecting Comfort Sports1 or 2 , im only asking as the Problem doesn't seem as Bad in the Sport Modes apposed to the Comfort. Thanks Guys.
