E63s W213 Build Thread
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
Hey guys
We are now happy to say that we have commenced and finished with our first step of planned works on this beast.
The entire list of planned work is as follows:
· Race Chip Tuning Box GTS
· Lowering
· Air Filters
· Down Pipes
· Tuning
· Wheels Magnesium Light Weight
· Carbon Ceramics
· Turbo Upgrade
· Akropovic Light Weight Exhaust
Race Chip GTS Black vs Stock
So we bought a Race Chip GTS Black tuning box to see how it would match up against the stock figures and also to see how it compares with our planned works to come, check the results out below
Stock Figures
WHP: 606.85 (679.67 BHP)
WTQ: 650.30 (728 lbs/ft)
Race Chip figures
WHP: 658.11 (736.96 BHP)
WTQ: 751.96 (841.12 lbs/ft)
Increases
WHP: 51.26 (57.41 BHP)
TQ: 101.66 (113.85 lbs/ft)
Dragy 100-200kpm
Stock: 7.34s
Race Chip: 6.67s
Santa pod stock figures
11.4s @ 122mph with wheel spin and launch control
Air filters
Also installed today were UPD Air filters pictured below, Map and dyno results to follow.
NEXT STAGE IS ON MONDAY SO STAY "TUNED"
John Laidlaw
Wirral
Land Rover Discovery 4
The stock figures on that were pretty impressive to begin Acid
Were you expecting that?
Quite a beast....
And I will be watching closely ( know someone else who will too I’m seeing tomorrow):)
V6Matty
Newark, Nottinghamshire
That will be beating the Black series in no time looking at those figures already,
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
Quite a beast....
I had ran 2 other E63s in the past and both making alot higher then stock so this was a expected result to be fair.
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
So Far my comparison is the E63s is a car that has impressed me up to 100mph but after that it seems slow compared to my C63 Black. Maybe I should not compare the cars as they are both 2 different platforms and the C63 is much lighter. The E63s does not scare me but the C63 still give me butterflies when I drive it as it is raw power rather then controlled power.
The C63 mid range performance is something else and I think its gonna be hard to get that from the E63s but let me see what happens. I estimate the c63 will get high 9s in the quarter mile while the E63s with bigger turbos will struggle to get into the 9s from what I have seen in the USA. It will be interesting to see what happens at Vmax 200 in March. I would be happy with 205mph as the C63 got 208mph. Just food for thought BMW M5 with 1000bhp got 213mph at the last Vmax so I have alot of work to do!!
Acid
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
Dyno Graph of the Race Chip to the Wheels
Stock Runs 100 to 200 km/p
Race Box Runs 100 to 200 km/p
UPD Air Filters Change
Down Pipes from Russia had these for a few weeks will install next week !! We will need to Remove the Gearbox as I dont want to cut the Stock cats out.
Will keep you guys updated
Acid
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
Right
A Few updates
Lowering
I have been in Contact with some guys called mbcansolutions who do the lowering modules for Mercedes. After a little research of other companies I thought paying over £1000 for a lowering module was not cheap. I did not want to use any lowering Links. Mbcansolutions lowering module cost just over £400 and I have to say I was quite impressed.
Module
Control inside the car -
The Module is plugged directly into the obd port and the setting can be changed from the Track Pad.
  • Factory (Factory level of your car when our module plugged in for the first time)
  • Low (Factory minus 32 mm)
  • Custom (by default same as Low, but can be changed by user)
All this takes is 1min and Job done and remove the module.
Finished Result
daveenty
The Frozen North :(
2019 AMG S Class Coupe
A good yet simple solution, though can it not be done through Star/Xentry?
I would have thought that would be easier, especially as you already have a machine. It does look well at the height you have it now.
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
Quick Update
Car is know Tuned with a Stage 1 ECU tune with Air Filter
Car is Running 765 BHP and now we have done some more testing from 100 to 200 km.
Next Stage will be Down Pipes and a fine adjustment to the map
SmartAmg
2011 E class coupe 350 CDI
That's impressive, 765 bhp
eek! :eek::eek: :D:D
Acid@MSL
Acid@MSL
WEST MIDLANDS
C63 SUPERCHARGED
  • #18
Did some more runs today.....
100-200km 6.16s
And 1/4 Mile
evans1089
C43/2017/3.0
Is that through the rear wheels or is it 4matic?
