ECU Hiding :)
Hello and welcome to the forum, some firms sell the 38 pin adaptors, cars from 1999 have the socket uinder the dash
Mercedes20001
Mercedes20001
S320 2001 W220 V6
Hi and thanks :)
So I need to look under the dash not the engine bay ?
Ad.
Hi and thanks :)
Ad.
The under dash were fitted from around 1999 onwards
Mercedes20001
Mercedes20001
S320 2001 W220 V6
This is the merc
Hope that helps ID is :)
Adam
whitenemesis
CLS55 AMG '05
Biggest help is to give the first 6 numbers from your VIN
BlackC55
South coast
C43
That code reader will not work. It is for 211 eclass not 124 which you have.
You need the pin reader. It is available on ebay usa.
The reader that you have is cr4p anyway and seldom reads all the codes.
BlackC55
South coast
C43
Your idel problem could be so many things. Take it to someone who knows these cars.
Mercedes20001
Mercedes20001
S320 2001 W220 V6
bugger.
I believe I've found the ECU:
kth286
E320 Coupe 95
cappsie
All diagnostic code readers are for plugging into the diagnostic plug NOT normally into the ECU.
AS was previously mentioned you have the WRONG code reader.
Your diagnostic plug is on the right side (off side) of the engine bay in front of the brake vacuum unit.
It is a little black plastic box some 2x3 inches with a pull off lid.
Inside there are 16 pin holes (connections) to plug a diagnostic code reader.
Not all the pin holes will have connections, some will be empty.
The main one for engine codes is number 8.
As you are not familiar with this you should find a Mercedes specialist that can read the codes for you.
Where are you located, perhaps someone can advise a good inexpensive specialist.
Is the car stalling all the time ?????????
Does it stall whilst driving it ??????????
That is not the engine ECU you have found.
The engine ECU is behind the battery behind a plastic cover (if still fitted)
Mercedes20001
Mercedes20001
S320 2001 W220 V6
ok fair point and *to* the point !
the car stalls - I start it, it revs, then stalls, it is not drivable.
kth286
E320 Coupe 95
cappsie
After it starts, can you keep it running OK by keeping your foot on the acclerator ????????
where you located ???????????
Mercedes20001
Mercedes20001
S320 2001 W220 V6
I'm in Southend - Essex
I can run it with my foot on the gas but it stalls if I let off at any point ...
type49
Could be a big air leak. Also throttle actuator could cause this.
Mercedes20001
Mercedes20001
S320 2001 W220 V6
Does anyone have the right plug for my merc or know where I can get one ?
