Egr valve in w169 180cdi
lavivar
granada, spain
w169 180cdi
Good afternoon, and once again sorry for my English.
I request your help as I need to know how the egr valve on a w169 (180cdi) 2005 to clean it is removed. I need it because I have a witness to the engine running and the diagnosis says that it is gas recirculation.
any help is welcome. Thanks from Spain.
ZZZZ
Hi there :)
I assume the baumuster for your model is 169007, right?
Here's a link to 11 files in pdf format, that should give you all the info for removal of EGR.
https://we.tl/oXt07G62b4
These are the files:
Don't know anything about diesels, so might have missed some docs, I'm sure someone will advise if that's the case - that's part of the reason for the above screenshot.
Please note that, WeTransfer only keep files for a week, so they will have to be downloaded before 20 Oct 2016.
L
lavivar
granada, spain
w169 180cdi
Wowww, I have no words! Fantastic and super fast! That you are really the best forum available on the Internet Mercedes. Thank you, you've been a great help to me. I have already downloaded the records and I'll study
A huge hug from Granada, Spain.
P.S. indeed, it was 169,007
ta9ao
Munich
A Class CDi180 2005 (W169)
Dear GLK,
I am having power loss issues in sixth gear just before 3000rpm. I am trying to trace the across potentially the MAF, EGR and DPF.
I am new to the forum and missed the posting of the documents by 8 days. could you please re-upload them for me? I have the same car W169 2005 on. Also anything related to the DPF would be of interest for me.
Many thanks!
ZZZZ
Here you go: https://we.tl/vSeqsh9Son
Again, they only keep it for 7 days, so ... ;)
I'm afraid my auto-mechanical prowess does not extend beyond changing an air filter LOL
ta9ao
Munich
Thank you
Got them..
Many thanks GLK!!
:D
S K P
A 180 cdi W169 2007
Hi there :)
GLK, would it be possible to repost these files? I'm trying to remove the ERG on my 2007 A180CDi.
ZZZZ
I don't have the set anymore, apart from the first four files (my car is petrol), so would need to pull the rest from WIS again, won't be able to do that before Tuesday, I'm afraid.
S K P
A 180 cdi W169 2007
I really would be obliged, if you could do that on Tuesday.
S K P
A 180 cdi W169 2007
Thank you so much GLK, I really do appreciate it. :).
I'll have a go once the weather improves.
Many thanks once again.
Vasco
A Class 180 2007
Hi there :)
Good evening,
I know that this thread was a long time ago, but I'm having similar issue with my MB and I can't find the service manual anywhere.
If you could provide me these pdf's files I would be really thankfull.
Much appreciated your help in advance.
Kind regards,
Vasco
KickNurry87
2007 W169 A180
Once again... could anyone please post the details of how to remove/replace EGR vlaue for W169 A-class (CDi 180)
Many thanks in advance!
ZZZZ
Let me see, if I can upload these files one by one here, once and for all, rather than posting links to 7-day We Transfer uploads of a 5MB archive, that's to big to attach here, over and over again (I'm a lazy git) ...
20 files in total:
  • 160 CDI Remove_install fuel filter.pdf
  • 169 CDI Exhaust gas recirculation.pdf
  • 169 CDI Inspecting cooling system for leaks.pdf
  • 169 CDI Pour in coolant and bleed cooling system.pdf
  • 169 CDI Remove_install air filter housing.pdf
  • 169 CDI Remove_install bottom parts of soundproofing.pdf
ZZZZ
More:
  • 169 CDI Remove_install diesel particulate filter.pdf
  • 169 CDI Remove_install exhaust gas recirculation cooler.pdf
  • 169 CDI Remove_install exhaust gas recirculation hot gas pressure transducer.pdf
  • 169 CDI Remove_install exhaust gas recirculation positioner.pdf
ZZZZ
And some more:
  • 169 CDI Remove_install exhaust gas recirculation positioners.pdf
  • 169 CDI Removing_installing the air intake pipe.pdf
  • 169 CDI Removing_installing the oil dipstick guide tube.pdf
  • 169 CDI Removing_installing the temperature sensor.pdf
  • 169 CDI Removing_installing the vacuum transducer.pdf
ZZZZ
Last five:
  • 169 CDI Replace air filter element.pdf
  • W169 WIS Bottom Parts of Soundproofing.pdf
  • W169 WIS Drain & Pour in coolant.pdf
  • W169 WIS Notes on Coolant Level.pdf
  • W169 WIS Pour in Coolant and Bleed Cooling System.pdf
