EGR Valve on W203 C220 cdi
Baldrick123
W203 "03" 220cdi
Can anyone let me know where about's the EGR valve is and how to clean it.
Andy
B
Baldrick123
W203 "03" 220cdi
Thanks very much for your help Lynall.
Andy
Althebuff
not very impressed only tried to open a file and it would not open
Koopa
C200 CDI W203 2004
on a w203, looking from the front its more or less top right hand corner (about 2/3 way up from front), it has a small black rectangular cover (with some writing on it, part# etc). Can be a pain to remove but I understand the black cover will come away to allow for cleaning, a more experienced member will have better detail.
jackwall5
Vienna. Austria
W203 C220 Cdi Automatic
Hi, if anyone has a picture of this from a w203 to share [ early model especially ], it'd be much appreciated.
Update: I found the following pictures in this thread ....http://forums.mercedesclub.org.uk/showthread.php?t=39449#post260491
.. but this thread is for an ML. I think I have this same item in my car very close to the thermostat! For some reason, it is not what I expected to see on my car :confused:
Safe Driving
thomasWW
New Registration
Crewe
C Class w203
Check and clean the ERG valve on a w203
To check and clean the ERG valve you don't have to remove it from the engine. On each side of the ERG plastic cover there are two clips. Carefully lift these and remove the cover.
The ERG valve should spring closed and be opened by the engine management system. Clean it up, removing all the soot and check that it springs closed. I put a very small amount of grease on the moving parts. When finished, clip the cover back on.
Hope this helps
Tom
