the only flaw of the W220 is there are no jump points in the engine bay. It is direct to battery only - in the boot.
The other way is to get under the car and put cables on the starter.
Do you have a power close boot? Did you try lifting the boot to open it once unlocked?
Otherwise, get the bonnet open and apply power to the main battery feed into the fuse box on the left side of the engine bay. You can also pick one of the positive side of the largest fuses. This should give you enough power to cycle the central locking and power the boot open.
Note, sometimes you need to repeatedly pull on the door handle when unlocking the drivers door to pop the lock fully open.
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
