S50OOL
- Mar 13, 2017
- Location
- New Deer, Aberdeenshire, Scotland
- W220 S500 1999 & W116 450SEL 1979
This fault now has me perplexed. We have a c180 kompressor 1.8 petrol 6 speed manual, 2005. We have 4 other cars so doesn't do great mileage in fact 1006 miles since last year's mot. When last driven all was fine. Getting it ready to go for this year's mot on road it throws esp light up and then within couple of seconds and light up on dash. If I stop it resets but then same scenario once travelling. I'm lucky enough to have my own star set up and the code showed was for right side multiple ring so ordered and replaced and erased code. Road test still had same experience so to rule out I put ring in wrong swapped osf and nsf hubs expecting to see fault transfer. No still the same faults showing. Then checked the sensor but showed as ok but changed to new to be certain thinking it's the only other possibility. Road test shows same results on star. Have checked and cleaned the connections all way back to N47-5 esp,aps and bad control module. Checked integrity on loom and all appears perfect. Swapped the ecu on a chance but still the same. Have reset the steering angle sensor and nothing I can find alters the problems. Can anyone take pity on my insanity and point me to anything obvious I am missing and not so obvious. Star showing nothing else at all. The only other thing I find is sometimes it shows as a stored code others it is present and stored but no rhyme nor reason to it, mostly shows as stored but wanted to mention this if it means something to someone. Thank you for reading my long post but wanted to try and convey all I have done to ensure it doesn't waste extra time saying I tried that!!!
