ESP fault with CLK320
Kevin Edwards
New Registration
The ESP warning light keeps coming on and it shuts down the power forcing me to pull over, shut off the engine and re-start. Its happening every 15mins or so. Any idea what might be causing the problem?
Hello Kevin and welcome,, this could be a speed sensor fault.
First turn the steering from lock to lock 3 times to re set the ESP,, if it happens again, then you will need to get the fault code read out on STAR
