Exhaust White Smoke
David Merc
2001 Mercedes-Benz (w203) C200 Classic 2.2CDI
Hello! I have a 2001 Mercedes-Benz C200 Classic (W203) with an 2.2CDI engine and recently I saw that there is some white smoke coming out of the exhaust. This problem started recently and after 15-25 minutes of running there is less smoke. I have no idea what it could be, maybe you guys know.
It had no engine mechanical problems or any important engine part changed.
Here is a video that may help you find out the actual problem.
D
David Merc
Keep an eye on the radiator fluid level.....if it's not going down, you can relax, it's just steam condensing.
I'll keep an eye out and come back with updates if it's the radiator.
onefortheroad
uk.
Drippy injector ? Add fuel cleaner
onefortheroad
uk.
This would be more black smoke - too much fuel = bad combustion burning
Like on a morning when you have glow plugs off . its white smoke .. I mean
D
David Merc
Update :
The exhaust fumes smell like carburant but how can I check where the combustion is incomplete?
Frontstep
T210 320cdi
Is this is on startup from cold and the engine runs a little bit "lumpy" when it starts.
mioba
Nottingham and Köln
If it’s from startup on a cold engine then I would say condensation and nothing to worry about provided it’s gone once car is up to temp.
Dripping injectors give white smoke as they tend to dump fuel in at all times so it goes out the exhaust as vaporised fuel.
overfuelling injectors give black smoke.
Update :
its probably an injector with poor spray pattern/or dribbling . A leak off test will confirm which is affected.
Frontstep
T210 320cdi
Me to for the injector but I would expect it to start a little lumpy.
