Fault codes: P246309 and P010106! Help!
Razzak
2012 C220cdi W204 coupe
Hi guys,
New to this but already need some advice.
Two weeks ago coming off the motorway and she went into limp mode. Had it checked and it was a turbo intermittent fault, code cleared, everything back to normal.
Two days ago back into limp mode with the codes P246309, P010106!
I understand that the DPF may be clogged? Whats the best way to deal with it, any advice is help as I hear it is quite expensive to deal with?
(2012 c220cdi coupe W204)
Thank you!
Craiglxviii
Cambs UK
What code reader are you using please?
R
Razzak
Ethos? I'm unsure as I took it to my local just to get the codes read.
Craiglxviii
Cambs UK
I won't comment on the codes as LK has most helpfully done so.
However- to properly read fault codes on a Mercedes, you need an MB- specific reader/ scanner. Generic code readers will not necessarily tie up with MB DTCs and in some cases can differ quite far from what the MB code actually means.
iCarsoft i980, iCarsoft MB-II are the ones most commonly used. There are others though- a quick forum search will bring up some possibilities for you.
R
Razzak
Thank you for your help guys
www.W140.co.uk&www.r129.co
