Fitting DAB into 2003 Mercedes
rebecca
E220 Estate Avantgarde 2003
I have a 2003 E-Class Mercedes Estate.
I travel around the country and get limited radio reception.
Is it possible to get a DAB radio fitted into my console and not be given a silly bill?
I don't need Sat Nav just DAB to receive a decent signal to listen from all parts of the UK!
An electronics company suggested the Alpine UTE-204DAB, Im not struck on the look of it (looks a bit dated) ...
Anyone have any ideas?
Rebecca
I added a Nextbase DAB 250 into my Aux in socket - hard wired and works really well
JBell
Torquey
C350 CDi Estate (GAD Edition)
If you have Amazon then the Echo Auto streaming through your phone is reliable
AnthonyUK
Alton, Hants
C240 estate 2002
I fitted an Android unit into my S203 with DAB+ and it is generally excellent but DAB reception is not great.
I do have one last thing to try which is a splitter to use the FM aerial which is excellent.
If you only want DAB then I would agree that you will get better quality and reception by streaming from your phone if you can.
I recently bought a SIM with unlimited calls, texts and 100gb of data for £10/pm on Vodafone.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
If you age getting limited radio reception with your current VHF radio then there is a fault with it.
DAB coverage is nowhere near as good as the old VHF band.
The antenna amp regularly fails on older cars, & gives the symptoms you describe.
stevebez
The Pure Highway 400 is a great piece of kit. Cannot connect to 12v and have to use a USB adapter… and you have to use the one provided other wise your signal goes to pot.
HankScorpio
W211 E320 2007
I installed an alpine ezi-DAB. It's a rebranded (cheaper) Pure Highway.
Also does Bluetooth phone and streaming.
Cheap as chips, took less than an hour to fit. I bought it with a cheap amazon cigarette lighter socket and plumbed it in behind the cigarette lighter in the dash.
horatio
Herts
190E, CLK
I fitted a double-din kenwood dab with an autoleads film antenna to my CLK. It actually works ok although it seems to cut out in specific places which are near some form of interference. A cheap solution anyway. The stereo was on sale at £100, aerial £20
in Halfords.
