PROBLEM - Fuel is not transferring from the n/s to the o/s portion of the fuel tank - so the car runs out of fuel with the guage showing 1/2 full. Problem started 4 months ago after changing fuel filter and putting injector cleaner in the tank. I still use the car daily but take care to keep the tank above 1/2
With a full tank of fuel, at rpm of ~ 2000 and above, air bubbles can be seen in the feed pipe from the filter to the lift pump - but non below 2000 rpm. With a lesser amount of fuel in the tank (1/2 to 3/4 full) air can be seen in this pipe even at tickover. In addition, intercepting the fuel return to the tank n/s at 1000 rpm and above reveals air / fuel slugs.
I suspect the air is responsible for the problem - i.e. the air-laden return will not initate the required venturi suction effect within the fuel transfer eductor in the tank n/s (I suspect air in the fuel supply will also result in the rail regulator restricting the tank return flow as it attempts to maintain rail pressure)
I have so far replaced the lift pump, rail regulator and pressure sensor, fuel filter and all the rubber and plastic fuel pipework between the tank and the HP pump. I presume the HP pump is ok as with any fuel in the tank o/s, the engine starts readily and runs normally
I am inclined to think that the source of the air ingress might be the o/s swirl pot due to some internal failure (eg separation of welded seal)
Been on with this for months now - can any experts suggest a way forward please?
