Gear box
Josif
New Registration
Hereford
Mercedes S320 ,2001
I would like to buy a second hand gearbox on ebay ,the part number is A1402712601 and I would like to ask you if there is any other compatibile gearbox model with my S320 ,2001 Mercedes.(for example I saw a lot of R1402712601 ,the number is the same just the letter is different)Thank you
whitenemesis
CLS55 AMG '05
AFAIK 'R' denotes a reconditioned part
Irresistance
Gdansk, Poland
2004 W220 320CDI
The part "A1402712601" is the part number for the transmission housing only and is NOT the part you ought to source for your car. The housing may be identical across all 722.6 boxes, but the contents of it (the stuff that actually matters) is very much model-dependent. You must buy the exact same number as your car already has.
This is something like 722.6xx. For example, the W210 2.7CDI is 722.634. Fitting that particular gearbox to, say, a 3.2CDI is absolutely not recommended. They have different programming for shifting patterns, torque settings, and so on. They may look identical, seem identical, and cost the same amount of money, but it is NOT a good idea to use a different number than your car came with originally. If you do a VIN number check on your specific car, it will reveal your exact number. Look only for that number.
