gearbox 203
deadman
can any one tell me were to check and fill the oil on a c class 220 cdi diesel coupe 2002 year.as 1 st gear and reverse are difficult to select wend left over night more so when its cold.i usually select 2 nd or 3 then it goes in more easy .its ok when it run for a mile .also as any one tried any additives in the gearbox any recommendations?
D
deadman
  • #2
still no clues
as i have asked the above question now on so many forums does any one know of any links to any sites which may be of h e l p as the question seems to difficult would any one have recommended oil for this gearbox someone some ware must know i wish i could get a workshop manuel
I have put the mod up in the DIY section that involves reducing the oil level, and that will fix your problem
D
deadman
sorry television l:confused:ooked in diy section and cant find it as I'm new could you or any one direct me ta :confused:
D
deadman
thank you television ive asked on at leased 5 sites with no replies your the first reply regards deadman
www.W140.co.uk&www.r129.co
