lots of diesel fuel is leaking from a drain hole, seems the hole is for drain purpose, which is at/on top part of transmission. We noticed that it used to leaking/drain engine oil from there, after fix the engine oil issue, now it is leaking fuel from the hole, we can’t figure out why, it seems there is no connection between the drain hole and fuel, where is the fuel coming from?
Have checked all the fuel line and return line, there is no leaking, one fuel injector is a bit leaking from outside but it is not the cause of leaking drips lots of fuel, after turn the engine on, we can see from the bottom, it starts dripping.
except the fuel line, is there any other place can cause the fuel leaking like this? can cause the fuel leaking into the drain hole?
if fuel injector faulty, can it cause the fuel leak from inside the engine to outside into the drain, not go through the fuel return line? Is it possible?
need help, please
thanks!!!
Mark
need help, please
thanks!!!
Mark
