Alex Crow
- Jul 9, 2009
- Location
- Super Suffolk
- W169, W124, w202, W203, KTM 250 EXC, VW T25 camper and a Polo in a pear tree
Hi thought about some resin in the gap between the electrode and the plug body so as to steady the electrode whilst you drill it for the tap
I still reckon that the tip could be removed
I noticed that the tip is only a press fit in the plug body no crimping etc so I could under cut the plug body inside the bore where the tip would end up to leave a step and then flair the tip end in to the under cut creating some interference fit, using the long screw with the slow taper to flair the tip in to the under cut, make it long enough to leave in and use the other end to jack the whole thing out.
Kevin
yes, i get it, another good idea. you have been thinking hard about this one kevin. is the tip material malleable enough to flare out? looks a bit brittle to me...
