Green Rubber Help Please
Slartibardfast1
W221 S350L, R231 SL350 & SL400
(2011 S-Class W221 S350L)
I've noticed that the inside rubbers (between door and window) are very green (algae?). These rubbers are quite firmly fitted against the windows and I don't want to try to prise them away to get access to the inner side to clean them because I'm concerned I may cause damage. Can anyone suggest an easy way for me to bring them back to black? Cheers.
V6Matty
Newark, Nottinghamshire
I’ll follow this as I too have green rubbers developed on the 212 where it’s parked next to the garage these days
Slartibardfast1
Slartibardfast1
Got some advice from the other forum:
I wound the window all the way then used a cloth on the end of a toothbrush soaked in white vinegar. Worked a treat!
Slartibardfast1
Slartibardfast1
That’s brilliant news, I assume the vinegar hasn’t dulled the rubbers in any way?
No it hasn't dulled it at all. I'm going to treat all the window rubber to Gummi Pflege today to treat and protect them. Already done pana roof and all other Rubbers last week.
Morethanpolish
Stamford
CLK 200 Kompressor
Ive cured mine on various cars over the years with an old credit card (not in the usual way...) - just run it along the strip when dry and it powders off. Its flexible and designed to move a bit.
