drdre78
It would be a bitch if the new one failed next week.
Lol or heater matrix go next week.lol.
What are the indications the evaporator requires replacing, does it leak into the passenger footwell?
No it comes out as a gas.
The A/C in my R129 doesn't work, its had a new condenser and the system refilled. STAR diagnostics reports that the electromagnetic clutch on the compressor is not engaging but I wonder if this is the cause or the effect of something else?
Nope, i needed 6 8mm washered screws which were missing when i started, trick is, when you take a panel of, you tape the screws to the inside of said panel, you cant go wrong that way..............it takes a tad longer but you no what screws go where.......
A/C diagnostics reports pressure within spec but there is a recurring fault code for the electromagnetic clutch. It will not activate when instructed to by STAR. The coil is showing continuity with no breaks but when I try to activate the clutch with a 12v power source it pops the fuse. I think the compressor is goosed!:-(
Reading this...so glad my R129 does not have aircon
