hi I've had a mercedes technician out to my b200 and he thinks there's a problem with the ecu but hes not certain and want to know what problems people have had with there to see if the problems sound similar????
it was bringing a load of different codes up but his diagnostic machine wasn't showing up the ecu on it and it wouldn't start but then when it did show up the car started and that's what he's baseing it on!!!
the problem with the car is I was driving it at weekend and it cut dead whilst I was driving about 3times and came up with dashboard malfunction, abs,esp then switched engine off then they went but drove it again and srs came and went now feels very juddery and still cuts out and intermittent starting
Multiple disparate systems impacted sounds like an earth problem.
In theory it could also be a CAN bus issue but I would expect diagnostics to catch that and log it.
It may also be an issue with the Electronic Ignition Switch (EIS) as that is also the CAN gateway to the rest of the vehicle.
It really needs putting on MB STAR by someone who is experienced with MBs.
You don't say where you are - there are several MB specialists we could recommend if we knew where you were based.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
