Rotorhead500
- Oct 19, 2012
- Location
- Very South Devon
- Used to have a C63...
Doh!
Well.... it should stop nicely!
Doh!
Well, the front end will stop, not sure what that back will do...
Scoob.
+1. Any snow on the roads and I leave the "good" cars at home and take the Hilux 4x4 pickup. That will go anywhere!
Don't be too confident with the 4x4,a Discovery went through the hedge last night not far from here, sort of proves what I was told about 4x4's , loose it and you really have lost it as far as control is concerned. After all if the road is like a skating rink nothing will grip unless chains or better still Caterpillar tracks.
For those who are deriding MB for grip, what is the most popular make of taxi in Germany Switzerland or Austria ? Makes a very good case for winter or snow tyres methinks
I'm going back a bit now .... 25+ yrs, but in Oslo or Helsinki (can't remember now - it was 25+ yrs ago ) everyone used studded tyres. They made a right racket on the road! Not sure how legal they are anywhere now these days though.
Tyres are now huge compared even to when I stared driving in '91.. My early cars had 145/13 tyres.. With fwd they went anywhere.. My 1st rwd car taught me a thing or two about grip, handling and poor conditions.!
You're right of course, if the road is a sheet ice a 4x4 is in trouble, but then so is every other vehicle that doesn't have studs, which, I'm guessing, is every other vehicle!
When it comes to tyres, I don't have winter ones. I prefer my 31x10.5x15 Grabber AT2s -
Between 1 December and 31 March are required by law to use winter tires if it's winter roads out there.
It's winter conditions if there is snow, ice, slush or frost on any part of the roadway. Keep in mind that even roadside counts to the roadway.
Studded snow tires may be used between the 1 October and 15 April.
Studded tires after 15 April
It is legal to drive with studded tires after 15 April and before 1 October if there is or is likely to become winter conditions.
Studded or friction tires
With winter tires meant studded tires or so-called non-studded friction tires. It may not be present in both studded and non-studded tires on the same vehicle. Note that it is permissible to use non-studded friction tires all year round, there is no restriction against them.
I learned physics at school in the 70s and from this I can conclude these irrefutable FACTS!!!!!!
FACT 1/ Fat DRIVE tyres gives MORE traction not less! (so those that conclude otherwise simply dont know physics) - i dont even need to drive any car in any condition to KNOW that as A FACT - but they also create more DRAG (for exactly the same physical reasons) making idle tyres (in MB case the fronts) very difficult to push through snow if they do not drive (probably where some of the guys dizzy logic stems from)
FACT 2/ Similarly Lower pressures (softer) DRIVE tyres give MORE traction but likewise they also create more DRAG on the idle tyres (again making it difficult to push through snow)
= Optimum traction is Wide/Low pressures drive tyre (for traction) and high pressure narrower idle tyres to reduce drag
I dont need to actually do any of this to KNOW it FOR FACT
Of course I will not take seriously any challenges to the laws of physics
There is no reason why Mercedes Benz should spin drive wheels in the snow - it can very easily be controlled and has been since the 60's (then called 'limited slip differential' - MB just haven't bothered to do it
Enjoying the Merc but I do not owe them anything to lie about a deficiency and blame Merc Drivers for being incompetant
I also did Physics at school in the 70's and passed my driving test in 1976 and through lots of practice I learned how to drive a RWD car without LSD in all conditions that the UK had to offer - Funnily enough my knowledge of Physics didn't help me then as its not helping you now
For Physics to work you have to compare all elements before drawing any conclusions ie:what works best on dry tarmac isn't necessarily the best in water snow or ice or sand ect.. and of course snow can be at least three of these things.
FACT 2/ Similarly Lower pressures (softer) DRIVE tyres give MORE traction but likewise they also create more DRAG on the idle tyres (again making it difficult to push OR DRAG through snow)
Except on snow it just gets compacted into ice. A skinny tyre will cut through more snow potentially allowing contact with the tarmac underneath
I doubt that many laws can be summed up in one sentence (as always "The devil is in the detail" alas you have omitted many detail
Very few cars had LSD in the 60's or 70's although most were RWD oh FACT!!!!! btw
Enjoying the Merc but I do not owe them anything to lie about a deficiency and blame Merc Drivers for being incompetent
