Headlight adjustment 107 - 300SL
Craneboy
Frimley, Surrey
Lancia Delta Intergale EVO 2, 95 e320 Coupe, 06 Honda Accord Exec Tourer, 03 Clio
The headlight adjustment on my 300 sl is not right, the near side is ok, but the off side is too low even when turning the dial to bring the beam upwards, can you tell me how to correct this please.
Only by bring the bottom out, that has the same effect
star
Reading
Smart + others :)
if the both beams alter when moving the range adjustment inside the car with the engine running then adjust it with the screws underneath headlamp trim. there are 4 fixing screws and 2 adjusting ones, the adjusting ones have countersunk washers on. if lamps do not move from vac switch or one does, trace vac leak.
C
Craneboy
Frimley, Surrey
107 headlight adjustment
Thanks Gents, it was the screw adjustment that was in need of adjustment, had it all to bits and could see that the screw was wound in so the beam was pointing very low and not too far in front of the car, even when the dial adjuster on the heater board was rotated. All ok now and Many Thanks
Thanks for posting back
www.W140.co.uk&www.r129.co
