Help needed identifying correct A170 bush
Disco Troll
Hi -
Got a typical newbie question here so hopefully someone can help me out. :)
I've got a knocking sound over rough ground from the front right of my A170 and the only rubber bush I can find that is damaged or in obvious need of replacement is part of the anti-roll bar set-up. Trouble is, is that there are *so* many rubber bushes under there, I'm not sure which one to order up.
I've attached a link to a dodgy pic of the bush in question - I might even need an entire new item rather than just the rubber bit - it's where the roll-bar unit attaches to the damper unit, up at the top near the spring.
All help would be greatly appreciated.
Disco Troll.
http://picasaweb.google.co.uk/gilesdesade/170?authkey=FqTloIVNciA#5246646960777702994
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Anti roll bar drop link, MB will have it in stock takes 30 mins to fit.
jib
