KPBangor
- Jul 11, 2017
- R129 1992 300SL auto
Hi, this has been an on-going problem over the past three years and I cannot get to the bottom of it. Over the past couple of months it has taken yet another twist.
The brakes on the car work fine at normal speeds and it has passed the MOT each year. However when comming to a road junction or traffic lights when I slow down I brake in a two stage fashion one to slow down and one to bring the car to a halt from 5-10 mph. The first application of the brakes is fine, but when it comes to the final- slow speed - application the anti lock brake system is triggered and the brake pedal kicks back, causing the car to take longer to brake along with a graunching noise.
This origionally started when I was parking the car with a lefthand lock on the wheels and then progressed to almost every time I applied the brakes at low speed.
Over the past few months when I start the car first thing in the morning the ABS light goes on and I DO NOT have the problem. When I next stop and restart the car the ABS light Remains out and I DO have the problem!
I have replaced front left abs sensor, both front wheel bearings complete with abs senders, front discs and pads, rear calipers and had discs cleaned. I have also experimented with s/h abs ecu and compressor. Non of which has made any difference. An auto spark has checked out the resistance in the sensors and tells me he cannot find a problem.
Any thoughts please
Any thoughts please
