Speedmaster
- Thread Starter
- Thread starter
- #21
Sadly David it is an aftermarket 6 cd changer etc. Although it is exceptionally complicated to use, so am considering swapping it for something more simple
Speedmaster said:Yup, the two catches are in different positions. Having looked carefully, they seem to be controlled but hydraulic cylinders and on the defective one, the arm is not coming out of the cylinder so the catch is not opening. It is hard to get to. I think this needs replaced. In which case it is not a big thing but looks like it might take a while (ie expensive labour) to get at it.
Speedmaster said:my worry is it says in the manual that if you disconnect the battery you have to reset things like traction control etc, if you look at that section in manual
markmerc said:Sounds like a hood controller problem. The ignition should be on but engine not running. Could be a cause of a microswitch not making,or worse luck the controller packing up.£750 from mercedes, you would be very lucky to get a second hand one! However all is not lost, the hood can be raised and lowered manually, allbeit it takes about ten minutes.Some cars were modified,so the engine can run and the hood operated.Check it out in the owners manual you got with the car.Apart from that, take the car to an independent workshop,get them to check it out on the diagnostics computer.
