Hi. I have a few electrical niggles to sort out for the MOT on my 1989 207D van. I need to get hold of a wiring diagram fairly urgently. Can anyone point me in the right direction?
The main problems I need to solve are:
1. that the drivers side Headlamp does not work on dipped beam. I have swapped the bulb and it is OK so I need to trace the wiring back.
2. The horn does not work. There is no power to the switch in the steering wheel.
3. It does not currently have a fog light but needs one, so I need to check that the wiring is there and if not I need to run some wire for the foglight.
4. The intermittent wipers have stopped working (not a big problem but annoying). I think this may be due to a fault with the little black box on the bulkhead which controls the wipers (I may be talking utter rubbish here).
Any help with the above would be greatly appreciated, although I would still like to get hold of a wiring diagram for future problems - I know there will be plenty!
