Peter Calin
- Jan 4, 2018
- 2006 E200 Kompressor w211
Hi all . I'm only new to the forum so please bear with me.
I have a 2006 E200 Kompressor w211 and I love the car but over the last few months it's been a nightmare for me.
Long story short : I failed the NCT ( I'm in Ireland) due to bad emissions AS it follows:
CO (low idle) : 1.45 ( limit is 0.3)
CO (high revs) : 1.53 ( limit is 0.2)
HC : 73 ( limit is 200)
I have done a lot of work on the car since the first test but it still fails the emission test.
The work done is :
Air filter, spark plugs, MAF, timing kit, catalytic converters, "oil leak stopers" for the camshaft sensor cables, wiring conectors ( at ECU) cleaned of oil contamination, vacuum breather hoses and valve , ECU reflash/remap, self adaptation reset, lambda sensor (pre cat/bank 1).
After all the work the emissions results did change but by only say from CO 1.60 to 1.45. My mechanic told me this is more due to the different values ( revs/ temperature) during the test.
I don't know what to do anymore.
Please , if anyone has any ideas or maybe I am lucky and someone did fix this problem , let me know .
Thanks in advance.
The work done is :
Thanks in advance.
