How do. I fix mirror glass??
android
2004 S Class 280 2.8
Driving me crazy
Can't seem to get this to stay put
Even with Velcro
Sent from my Redmi Note 4 using Tapatalk
Naraic
2005 CL500.
Undo the spring clip on the mirror and use that as it is intended to be used.
GlosRichCLK
Gloucestershire
2019 W177 A180 SE auto, 2012 W212 E350 CDi Sport saloon, 2001 CLK 230 K Cabriolet A208
Have to unclip the little metal bar at the top, push the mirror in then clip the bar back on to hold it in place. Mirror.JPG
A
android
You mean the spring bar thing running along the top
A
android
I'm a numpty
I still haven't sussed how to attach it back using the clip?
I'm trying to figure out how the clip holds the mirror to that circular back piece inside the housing
Put the mirror in full downwards position.
Unclip the wire at the green circled area (careful not to lose the spring).
Hook the bottom of the mirror over the round plate then hook red circled bit of wire over the red circled tag and clip the wire over the green circled plastic lug again.
Naraic
2005 CL500.
Have you undone the clip?
A
android
Yay
Think I got it back on using the clip
Thanks everyone....
A
android
Many thanks for the help
A
android
Damn
Looks like it's fallen off again...boo hoo
Submariner1
Windsor Berkshire
CL500 2009 5.5
Damn
If you are not sure how to do it.
I strongly advise you tape it Up and take it to an Indy or dealer.
Why
My heater in the passenger mirror went £85.
I thought that was steep, but was told the drivers side was £235 or £270! Cant remember.
Brizzle
Bristol (UK)
E220 AMG Night Edition Bluetec Auto Estate (Feb 2016)
Driving me crazy
Even with Velcro
Is that a replacement mirror glass by any chance? I had exactly the same problem with my W220 and ended up filing bits of plastic off the back of the replacement glass to get it to fit. Took me hours :(
A
android
i dont think its a replacement
more an problem i seem to have inherited from the last owner
first time i used the electric switch to retract the drivers mirror- i saw it dropped away from the housing
The trick is to ensure the two lugs at 4 and 8 are fully engaged when you put the spring back on at the top.
Lit.91
GB
MB
I think you're just not clipping it in correctly.
Also, from memory, there's no need to remove the metal clip - leave it on, align and affix the mirror at the bottom, then, with a longer screwdriver, the metal clip at the top has a section where it can be pulled away from the mirror to clip around the motor housing. The mirror should also affix across the top without the metal clip, I think the clip is used as a precautionary measure.
Also agree with other comments above, mirrors can be fragile and the auto dim mirror certainly isn't cheap £80-100 for a used one...
