How long would it take to replace both ABC reservoirs on CL500 C216?
Submariner1
Windsor Berkshire
CL500 2009 5.5
Just interested as ASRA says
1 hour for the front and 1.8 Hours for the rear one.
Hmmm
To replace front says:-
Remove left front wheel and wheel liner, and front engine lower protection.
then remove front valve block, undoing 3 fluid lines, then undo reservoir. And do reverse.
Rear says, take out boot inner floor, jack up car remove left exhaust, remove spare wheel tray and heat shield, then remove rear Accumulator and then reverse to refit.
Blimey 2.8 Hours seems incredibly quick to do all that? Plus I guess they would do a Star test?
what do you think?
Additioanl things (like bleed/fill etc) are often not included in the ASRA timings. "sometimes" These are illustrated underneath (does not include x y z ) and this must be included.
Would take is 3-4 hours.
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Front is relatively easy, did it in about 1hr myself just recently. Didn’t remove valve block, just unscrewed accumulator and screwed in the new one in situ.
Will let you know when I do the rear, but bought all new parts, including exhaust clamp in case in need to remove left hand muffler.
Are we talking about pulsation dampers, resevoirs or accumulators?
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Thanks is yours a W216 ?
WIS says remove front valve block, good to know the accumulator can just be unscrewed.
Submariner1
Submariner1
Windsor Berkshire
CL500 2009 5.5
Thanks I suspected so.
Reckon it would take me 6 hours - so going to Indy.
ajlsl600
france
I think Craig is ur man on this subject
dldb
CL500 (C216) 2009 107K miles 5.5l V8
How did they check it out? Did they check the difference between fluid level when standing and when running? That's the only way I can think of to check.
