How strict are police on expired MOTs?
Conor
London, UK
Hello.
So my MOT expires in August 3rd.
I was planning on being back in Ireland the last week of July, and there is a chance I might not get back in time for a fresh MOT. I don't want to do it before I leave, because I would like to put the car on the lift and run through a few bits and ensure all is ok (I think it needs one or two bits doing).
.. In the off chance that I do end up driving from Holyhead to London with an expired MOT (less than 7 days). What are the chances I get in trouble?
Conor
If you get stopped - high
You can drive legally to a pre-booked MOT
Doesn't state how far that is...;):rolleyes:
Larkone
NW Essex
C219 CLS 320CDI 2008
No MOT means your car is not cleared to drive on roads as roadworthy vehicle so that means your insurance may be invalidated - other than driving to a garage for work/MOT. Some explicitly require it others don't - best to check yours first.
ajlsl600
france
Yet I can run my old classic around no mot no tax 7 days grace wud harm no one.
sl500amgsport
Essex
SL500 2014
A local on our community FB group posted a parking notice he had received for his white van from Tescos by the private parking company for parking outside marked bays. He asked if anyone else experienced it and if he doesn't pay do they bother to enforce....
The local police are also members on the forum.
A quick check showed no mot on his car so I replied "the parking penalty is a lot less than that given, for example, for not having a valid mot.
Amazing how quickly the post disappeared!
Sent from my SM-G988B using Tapatalk
Alastairp
West central Scotland
2005 CLK200 coupe (now gone) 2011 R230 SL350 2014 C220 estate
I think it needs one or two bits doing..
Get them done now if they would fail an MoT (imho).
Stick in in for the MoT and see what comes up.
Or use another vehicle in the meantime.
Conor
Conor
London, UK
Hold on a second.. let's not lose the run of ourselves. You make it sound like the car is a rolling liability right now...
It's running fine and safe. When I say a few bits, a rear arm has a slight amount of play on it. Was same last year and wasn't even an advisory. The A/C needs a new compressor/pulley and I wouldn't mind having a look at the rear brake pipes and seeing what condition they are in. I've had new tyres on rear and fronts are decent. New pads and discs all around a thousand miles ago.
It's just that I plan on doing a bit of work on the car..and would rather just give it the once over prior getting it tested.. I would like to avoid getting a fail before I leave the country.. if I was to get delayed, for whatever reasons.. returning to the country on a failed vehicle would be a lot of hassle.
All my other cars are back in Ireland.
Rockron
Essex
709D/1990/OM364
I would do as post #2 pre book an MoT in London, although I seem to recall that it is expected that nearest practical Testing Station to point of entry should be used. I sometimes used to do that on returning from Euroland, pre the day when insurance cos adopted the requirement that vehicles "must have a current MoT even when overseas" was made more evident in the Policy Document's wording, some used to only stipulate that the vehicle was required to be in a roadworthy condition, possession of a current MoT wasn't specifically mentioned. I'm a bit surprised your Policy only requires 'roadworthiness'.
Then again a car with a current MoT isn't necessarily a roadworthy one.
But first I would check that the car (to the best of my abilities)would be likely to pass the test. If plod was to collar you for the sans MoT he wouldn't then have grounds to additionally charge you with the driving of an unroadworthy vehicle.
sl500amgsport
Essex
SL500 2014
Just a heads up there are a few "plod" on here (all nice and non vindictive by the way)!
Rockron
Essex
709D/1990/OM364
No worries I'm safe! My post implies interpretation as in stating 'should' rather than 'must' and the term 'seem to recall' implies an element of doubt. It is for the OP to decide if he considers driving straight home to London for a pre booked MoT is the most practical way to comply with law.
Certainly (in days of olde) when my MoT ran out whilst overseas I would prebook a test at my usual MoT station and drive straight there. No one could or would advise if this was best practice or not in the circumstances. I therefore made my own decision, as did many others.
These days I ensure my return from overseas occurs prior to MoT expiration, my Insurer currently categorically demands this.
sl500amgsport
Essex
SL500 2014
I'm sure they won't take offence at "plod" ;-).
Not MOT does not invalided the minimum legal requirement that the insurance has to provide third party liability cover.
Claiming on your own fully comp policy with not mot might be hard.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
When I was in the job 22 years ago & you renewed your MOT straight away, it was a warning letter in the post.
Fast forward to now with ANPR you are likely to get a fine in the post.
But as Blobcat states you can drive to a pre-arranged MOT, & the rules are very relaxed.
The decision is yours.
EmilysDad
Bury Lancs
ML350
a few years ago I ran around (locally) in my Smart for about 9 or 10 months with no MOT ..... complete over sight ..... no one came knocking!
I drove to France & back with no MOT about 6 or 7 yrs ago .... I realised the day before we were due to go away ..... again, no one came knocking
Not sure how good modern ANPR actually is
Dean Fletcher
Penrith, Cumbria
Mercedes E400
My wife didn’t have an MoT on her 107 for 6 months 2 years ago I only found out when she broke down and tried to get the RAC to recover her home. They called me and said because of no mot they can only recover to a garage. If she hadn’t broken down she probably still wouldn’t have one today.
I have magic wands on my hands you see not fingers.
Snake Charmer
S211 E320 CDI 2004
@Conor I aim for the 13 month Mot if possible and you are just before the 28 days to obtain that. If you have a regular place, take it within the 28 days, explain your dilemma and fix what fails then repair at leisure. ;)
Seeing the way you look after your cars l doubt you will have a problem.
