How To: Change front coil springs on a W203
nickid
coleraine
YELLOW LIMITED EDITION 2002 MERCEDES C 230 KOMPRESSOR SPORT WITH 2 TONE LEATHER
Have two compressor clamps and just bought another two to make sure
Pathfinder
Gourock
Your not going to find it easy with normal clamps especially on the rebuild. I took mine to a local mates garage and used his floor mounted, similar style as the above how to.
cleverdicky
MB
And when you've compressed them, have a mate stand well back while you release the stupid little round threaded retainer.
Because you need someone else that still has their eyesight to see where it pinged off to ;)
nickid
coleraine
I pray it doesn't. Need to do this myself since I don't have access to a garage to have it done
Pathfinder
Gourock
After you remove the struts from the car, you could take them to a local garage and ask them to remove/refit the springs, probably around a £20 charge.
Do check the top bearings while you have them off. Mine were well worn with a lot of side play and I had buy new ones.
nickid
coleraine
I took the sping off because of the top bearing not working.
cleverdicky
MB
The bearing is actually the hard rubber bit that stays in the cup in the wing.
I know I know :rolleyes::rolleyes:
But they are not expensive to replace, easy once you drop the strut and do make a hell of a difference. :D
nickid
coleraine
I first noticed when I could hear the top mount rubber turning instead of the bearing
SteveX
Always nice for people to take the time to do a DIY :)
nickid
coleraine
My wife said "just take it to the garage" lol women
Benzworx
South East
CLK 55 amg
Please guys really cant stress enough please take them to a garage with the right
spring compression tools, this is an accident waiting to happen and know you all want to save money on repair costs but is your life worth saving a few bucks !,
No is the answer
Frontstep
T210 320cdi
I watched someone take the springs off a 210 with big pry bars !!
Mind you it wasn't as entertaining as watching petrol tanks being removed with a gas axe.
Pathfinder
Gourock
Not on a 203. The strut does need to come out and removed from the strut. It does not remain in the wing.
nickid
coleraine
Taking it to a garage now. Needs to be nearly fully compressed to put the top on. Thanks mercedes
cleverdicky
MB
You are correct. I stand corrected. :(
I think the ordeal confused me until I checked with pictures I took.
Hope you get them sorted OK but you made right decision taking them to shop.
Nasty things.
