How to remove this connector? Rear Seat Air Valve
lordgaz
Herefordshire UK
W220 S-Class S55 AMG 2000 / W220 S-Class S55K AMG 2003 / W163 ML270 / Jaguar XJR X350
Hi All -
Please can you help advise how to remove this type of connector? It did not seem to remove intuitively, and I have a long track record of breaking things - so rather than persisting, I thought I would ask first!
(I am wishing to disconnect it as I apparently have leaks in the back seat air cushions, and although I have had the PSE pump output for the seats disabled to save the pump, I still hear this valve block going through the motions and just thought it best to disable it also until I get round to fixing the air cushions) -
Alternatively, if this part is on its own fuse, does anyone know which fuse it is?
[URL=http://smg.photobucket.com/user/lordgaz/media/Connector_zpszqu5laxk.jpg.html] [/URL]
drdre78
london
mercedes c200 200
Hi the part that goes round the top on connectors pull back but first in middle of connector must press tab down then it will pull back.
drdre78
london
mercedes c200 200
Hi pulls down towards module
lordgaz
lordgaz
Herefordshire UK
Thank you -
Do you mean the part highlighted moves (see image) ? (sorry, I am not sure yet)
[/URL][/IMG]
lordgaz
lordgaz
Herefordshire UK
Haha - Thanks -
I cannot get it to move in that direction - Is that the part which I need to push in or pull outwards first before pushing in the direction of the arrow? or are there other "tabs" to consider?
drdre78
london
mercedes c200 200
Before you get it to move.there is tab in middle of connector you need to press down so it will move
lordgaz
lordgaz
Herefordshire UK
Thanks for the help - I have removed it now!
