I can't believe this. Did I just kill my transmission?
Benx99999
2000 E320
2000 E320
I had over 2 years of trouble free service from this car, and in one day it's trashed. See my other post regarding a bad ground effecting my lights and engine quitting. (in electrics)
It turns out that the turn signal cuts the engine out too. I was coming to an intersection to make a turn, put the signal on and it cut the engine. I had traffic right behind me and I panicked a bit and threw it in park to get it started again. Turns out I was still rolling , maybe 2 mph or so.
Now I can't move the shifter out of park. It won't budge. Any thoughts on this?
mikestrivens
Stockport
It won't move unless your foot is on the brake pedal.
star
Reading
Smart + others :)
Has the shift rod come off?
Arudge
Cradley Heath
CLK200 2000 Kompressor
And if the brake pedal switch is buggered it still isn't going to move.
To add to LK's comment on your other thread, you've got severe earth issues. The same goes for the engine and transmission, if it's not getting full voltage, it's going to shut down.
These issues should show up as low voltage codes, i suggest you get the codes read.
Tel: 020 8863 9233
