is that not a switch allowing vacum connection to pass thru ,or not, when certain temp reached, the top looks like openings x2 not wire connectons, cud be wrong think i hadsomething similar on my 230GE ,but 20 yr ago and memory not wot it was
Thumbs up for that it is a thermovalve , one pipe will go to the fuel metering unit and other to the regeneration valve . The plastic tube parts that are broken off , and missing from the valve are not the same as one is set at an angle and one upright . The upright one goes to the regeneration valve , and the angled one to the lower part of throttle or metering unit .Dont know what the engin is but most are like it . pm sent
banman you part number will be on the valve .The opening time on the valve is the one you look for .And come by colurs white and black red with black bands . You need to pull the old one out .Dont do what i did removing it and snap off one of the two tubes,. But in your case this could happen when your fitting ..
banman this is the diagram and the valve .You will see the markings on the flat part .Thats the value you look for on your valve .I think this is the right valve but check it with yours.Diagrams are a 100000 fold in images on the google search page, look to the r/h side top of google search .You will see - images click on it to bring up another search page .I put in R107 engine vacuum diagrams .Nice car by the way one of the true classics.Looks like you have two thermo valves ..
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
