sineda
- Dec 27, 2016
- Location
- East Midlands
- Mercedes B180 CDi SE
Today my pre-facelift B180 CDi glow plugs light came on, it stays on for the first 2 minutes and then goes off. The light will only come back once the engine is fully cold, which if I understand correctly, is the right thing because glow plugs are used to help diesel engines start up in cold weather.
The problem is that no indie garage wants to take this job because apparently a B-Class is a nightmare job to do - that is, replacing the glow plugs because a lot of things needs dismantling as well as the coolant draining (form what I heard), etc. I called a local MB garage (not main dealer) and they quoted £499! They also said that if the glow plugs are hard to take out, stuck or snap, then they'll need to call an engineer, meaning the cost goes up to £799!! FOR FOUR GLOW PLUGS?!?!?!?! I kind of lost the will to own this B-Class now. Are all Mercedes this hard to replace or is it just the B-Class?
