Is it possible to change the engine and Gearbox oil on Ramps.
Brian23
EClass
I used to have access to a car lift and did all my own servicing. I no longer have this facility, so is it possible/easy to change the lubricants on only drive on ramps? 2005 Eclass Estate.
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Lots of us on here change the oils using a pump and don't even have to bend down. Lots of posts about it on here, have a browse.:)
Linuus
crawley
w210 wagon
Pela 6000 that’s what we here use ;)) best thing ever
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
I marvel at how easy my engine oil and filter changes have become since investing in a Pela a few years ago. Wonderfully easy and clean.
daibevan
Alltwen, Pontardawe
Or if you're tight, like me, a Lidl pump, though you need to have an empty oil container at hand.:D
umblecumbuz
Wales and Gozo
Do you get the feeling that these guys can't bend down anymore?
The Pela has really changed my approach to oil changes. Trouble is, I now do them more frequently, so the on cost needs to be taken into account!
mioba
Nottingham and Köln
When changing the gearbox oil one should change the filter, gasket and give the sump a cleans
You can't do this without accessing the sump so how is the Pela handy for this.
Just saying mind :)... Pela of cousrse only useful for engine oil.
Jim2
Sure it is possible, I've done it on wooden blocks and axle stands. Not as easy as on a lift, but definitely doable. As you can see from the posts here, engine oil change's are now mainly done by suction pumps. The transmission and differential of course has to be done from underneath the vehicle.
umblecumbuz
Wales and Gozo
Thats how I do mine, by removing the gearbox sump, along with many others on here (5g box).
But after you've had the sump off and renewed the filter and replenished the same amount of atf that you drained off, there is still the torque convertor and the cooler radiator with its pipework to drain.
There is often no drain plug on the torque convertor, and it's a right pain to completely drain the cooler radiator and its pipework. That's where the Pela pump helps. Using the pump is a cleaner way to complete an atf change, by running the car then removing, say, 2 or 3 litres, then replacing it, then repeating the exercise. This helps to renew the atf throughout the box - including the torque convertor and the atf cooler and pipework.
rapide
west sussex
1997 E230 (no rust) 2016 volvo xc60 r/design. se. lux. nav.
I used to have access to a car lift and did all my own servicing. I no longer have this facility, so is it possible/easy to change the lubricants on only drive on ramps? 2005 Eclass Estate.[/QUOTE
changing e
yes you can do it , on the floor with ramps . put the front on ramps and jack up the rear on stands so the cars level. if you are outside, pick day thats not windy or you will get all the dust blowing up around the guts of the box! I did mine as stated up against the side of a garage ( it wouldnt go in) very still day get the box sump off drop the filter replace it wash out the sump quick and wack it back no problem. watch your oil level in the box , temp / dip stick! engine and diff easy!
Jim2
I managed to do the transmission on mine while it was on stands and blocks, was my first time ever changing the trans oil on a Merc, and for sure only for the help and advice I got here on the forum ( Thank you all :) ) it would have been problematic. Now that I have crossed the bridge of the 1st change, will not be afraid when ever I have to do it again. One thing that I would do for the next change is to get a banjo bolt fitting, with a connecter for a plastic hose to drain the oil from the return coolant pipe. It definitely makes the job cleaner and easier. I think that there is a purpose built fitting available for this, maybe some one here knows where it can be got? For me, I managed to put a length of hose on the bolt with a jubilee clip, it worked, but still leaked a bit of fluid as the existing banjo bolt is a bit short. It definitely makes the job a lot easier.
B
Brian23
EClass
But you can't replace the filter this way.
B
Brian23
EClass
Does anyone have the service sheets for this, so I know I am doing it all correctly? 2005 E200 estate.
Jim2
Search here on the forum for 722.6 transmission oil change or alternatively, Google Mercedes Benz 722.6 transmission oil change it will direct you to several sites, with step by step instructions.
Good Luck
umblecumbuz
Wales and Gozo
Read my post again:
"But after you've had the sump off and renewed the filter and replenished the same amount of atf that you drained off, there is still the torque convertor and the cooler radiator with its pipework to drain."
Jim2
Read my post again:
Yes umbelcumbuz, you are right about sump drain and filter replacement. That was why my input was to detail draining the TC, coolant pipes and Rad...like I said, with the proper banjo bolt connector and tube, it's simple. Drain 2 litres, refill 2 litres, until the new red coloured fluid replaces all the black stuff !!!! :):)
