Just brought a mercedes E280 Estate
Waders
280e estate
Can any recommend a obd code reader what doesn't break the bank on a older mercedes w211
E280
2006 MODEL year
That can reset sevice lights and read fault codes for the future so I can work on her.
Many thanks everyone
Wearsafoxhat
Sunny Hampshire by the sea
Icarsoft MB version 3 which I think is the latest. A pre owned ( as this is a Mercedes Benz site ) MBII is fine if upto date with software.
Just buy it from a reputable dealer..
Hello and welcome
axelcls
Kettering
Mercedes w218 CLS63 AMG now gone, RR Velar
Hi and welcome
ajlsl600
france
Hi. Grand budget... Icarsoft mb 11 or 111
. It WIIL save u cash.. Until u learn more you can post codes on here or use ur buddy goole. Its a no brainer for any modern benz owner not wanting to be shackled to the stealer
00slk
Cambridgeshire UK
Hello and welcome
Craiglxviii
Cambs UK
Autel AP200, £50
SmartAmg
2011 E class coupe 350 CDI
A late, welcome. :)
SA1
Cambridge
E320CDI/2006/3L
HI,
I bought my Icarsoft mb obd for my w211 2006 e320 some years ago. It has proved invaluable, I have used it many times.
I have an electronic braking system (SBC) and you have to depressurize (and later pressurize when your work is done) the braking system as a safety measure before any brake work (pads/discs/new fluid etc) is performed, so it's great for that.
I have changed the gear oil which requires oil temperature during the process, which you can access to on the obd.
It is also good for fault codes, say if you have a wheel speed sensor issue - the unit will identify which wheel is the problem sensor of your ABS.
For just over £100 it easily pays for itself.
