B
billf73
Hello,
I just bought an old (1985) L407D van to convert into a mobile home... its done about 70,000kms, seems to be legit as I have all the papers. I'm far from being a vehicle expert & there were a few things wrong from the start... clutch failed completely while on the motorway shifting from 5 to 4... total loss of power & a loud noise. After the clutch was really hard to press and doing so made the engine grind to a halt. Also the exhaust pipe became dis- connected from the engine... very loud. These things are now ok.
But I have a new problem, a fairly hi pitched whining noise which occurs in the 1st few mins after starting up, usually while in the lower gears (2-3)... though it seems to be getting worse & it now whines for a longer period and I think in higher gears also...
The whining completely stops if you press the clutch in.
The last time I drove off in very heavy rain & the whining was the worst so far... also the battery warning light came on while or shortly after this was happening.
I should also mention that while on the motorway doing about 110km/h (5th gear with the pedal on the floor) for an hour or so the engine temp went up and some smoke came from the engine. I reduced the revs and the temp went down. I haven't driven it this hard since.
Any advice would be really appreciated. I'm not planning to fix this myself but would like to have at least a rough idea of the problem before i go to a garage...
Also I would like to run it on bio deisel if possible but I understand the fuel pump is not suitable. Can this be changed?
many thanks...bill
many thanks...bill
