james2747
- Jan 26, 2011
- Location
- Newent, Gloucestershire
- E270 CDI 2003
The car has covered 118,000 miles.
I have had this problem for well over a year ... and can't find out what is causing it.
Just normal 'quick' use of accelerator, as when overtaking someone, frequently results in the car going in to 'Limp Home' mode.
I'm not slamming accelerator to floor, just reasonable use of accelerator for example when accelerating to overtake another car.
It also doesn't occur every time but when it does, I have to find a safe place to pull over, switch off ignition .... immediately turn back on again and all is well ... limp home mode has gone.
It does occur every time ... if I test it out on a quiet road and push accelerator hard to the floor.
There are no fault codes, I do have an iCarsoft i980 code reader.
I've checked turbo shaft play .... virtually nil.
Engine crankcase breather renewed ... no difference, problem continued.
Have checked all vacuum pipes and connections (twice) and found them all to be sound and pipes not cracked but in good 'flexible' condition.
Engine is in good condition, returns over 45 m.p.g. on a run and oil and filter changed every 8,000 miles.
Any help, pointing me where to look for the cause of this annoying fault would be very much appreciated.
