Magic Vision Control
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
Just to be clear, if I buy that feature, hot young things will write their numbers on my windscreen??
As long as Mercedes specify the quality and quantity of attractive young ladies who are guaranteed to show an interest in me, I should think £627 is a bargain Malc!
Just seen this rather old thread. I have magic vision on my new S Class and although they wipers are OK at the moment I am now dreading it when they do go wrong. Do you change the whole blade or can you just replace the actual wiper rubber.
rorywquin
North Yorkshire
An old B-Class.
Looking at mine it is the rubber. However - will not be cheap!
My 1990 Citroen BX had windscreen washers in the blade. Right royal PITA when temperatures dropped below zero as the wind chill just froze it solid.
rorywquin
North Yorkshire
An old B-Class.
Hopefully MB have done their homework on their flagship models.
The current screen washers have heated water. The rubber is actually perforated along its length and I believe the washer fluid is supposed to be anti-freeze.
IIRC the older versions (referred to in these really old posts) had a couple of jets on the metal part of the wipers separate to the rubber blade.
I do like the fact that I do not get a shower from my washers with the roof open.
