Manual gearbox 2nd gear problem
daveyorks
2010 c class sport 2.1
Hi guys, my 2010 c250 saloon has a problem changing from 1st to 2nd,sometimes its stiff and a bit of a crunch .when i start driving it 'the rest of the gears up and down the manual box are fine.
it only happens when i first start driving the car and after so many miles it works properly ,had the gearbox oil changed and still the same
thinking of going down a gearbox repair or getting a warranted gearbox from a breakers
any suggestions?
MBW201
W201
Check all the rods from girshifter, have you changed fluid on the clutch slave cylinder? If its no easy solution maybe sync problems.
