Mercedes c270 cdi tuning
Discussion in 'Tuning, Styling and Performance.' started by dubburke, Jan 23, 2018.
  1. dubburke
    dubburke Active Member
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    I have just acquired a 65k mile c270 cdi wagon, I have just had a good service including aux belt water pump oil and filters, gearbox oil and filter is next, I love the car but would like to unleash the beast.
    I have just bought injectors and turbo from a 2002 E320 cdi with around the same miles.
    1.What exactly is required in order to fit the larger turbo? as apparently a few mods need to be done for it to fit.
    2. with regards to injectors are they straight forward fit?
    3. should I decat the car, both pre cat and main cat?
    4. Do I need different MAP sensor and uprated fuel rail?
    5. will egr delete normally come with the remap?
  2. fabes
    fabes Senior Member
    247
    54
    Nov 14, 2015
    Your Mercedes:
    E 350CGI Coupe
    Have you ruled out just a stage 1 remap as these respond quite well to one.....?
  3. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    I got the turbo and injectors for £200 with 65k on them, as I saw the car they were removed from, thought it was cheap, so would go the whole 320cdi route but without the 3 litre engine!
  4. Westheath
    Westheath Senior Member
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
    Yep swap over is simple for turbo and injectors no need really for egr delete but up to you.
    I would remove the inlet manifold flaps and tap the holes and fit bolts with thread lock,
    leave motor connected to stop fault codes, this modification allows for better tuning and prevents future problems with these plastic flaps being ingested or stop functioning.
    Remove cat innards usually cat1 ends up in cat2 anyway and blocks the exhaust.
    Upgrade brakes to drilled slotted discs and get a set of decent pads or do a front brake conversion to upgrade them.
    Take it for rolling road tune up a (generic remap wont benefit the upgrades), and then hope the gear box don't jump in to limp mode.
    dubburke likes this.
  5. LostKiwi
    LostKiwi Senior Member
    13,788
    5,211
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    I wouldn't bother with drilled brakes as they can crack around the holes unless they are cast in holes (expensive).
  6. Westheath
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
    I never fit cheap braking parts when upgrading.
  7. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    Any idea what sort of figures the injectors and turbo with generic remap would get?
  8. Westheath
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
    Generic mapping relies on standard oem parts and values for the ecu the generic remaps applied to, this then brings the stock engine alive a little by tweaking fuel and boost levels and eliminating other components if required DPF regen, EGR delete etc.
    Also.......
    Its all individual depending on original engine wear and compressions,
    upgrade component wear and tear also has to be taken into account
    that's why bespoke tunings a better way to approach it if you have used non stock parts for your engine.
    Also.......
    Tolerances with the injectors,Turbo, fuel rail, inter-cooler, boost pipes etc.
    So no hard in stone set figure just have a RR session and go for the tune your after.
    I usually go for a eco tune with a small boost at the top end,
    this gives me good cruising mpg and plenty of overtake boost,
    if I need to get out of trouble.
    Off the line speeds not important for me any more,
    We have an old track day BMW M5 to suppress my public highway urges.
    PS: I'm interested in your old injectors if you're selling them :)
  9. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    The injectors and turbo arrived, sent them back, the injectors were covered in black death and the turbo had play, so bought a tunit tuning box, good bit of difference, actually drives smoother than before with it fitted, looking for nice wheels now
  10. Westheath
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
    Have fun covering the road in black exhaust crap then
    especially at night with those tuning boxes.
    It sits on the end of the common rail and dumps extra fuel in.
  11. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    No smoke, day or night, I am sure the cheapy tuning boxes would, but tunit do half decent ones
  12. Westheath
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
  13. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    UPDATE.
    Well bit the bullet and got a remap (Westheath you were correct), it is like night and day compared to the tuning box.
    I was getting intermittent cutting out on full power whilst overtaking which was scary.
    I had the car diagnosed as fuel rail pressure too high, but I only noticed the cutting out since the fuel filter was changed to a non Mercedes filter, had a OEM one fitted and now it seems to be sorted
    gearbox oil was flushed and changed
    new water pump and thermostat
    full service
    discs and pads.
    night breaker bulbs
    Bought a set of refurbed AMG R170 alloys with polished lips, will wait to the better weather to fit them.
    One question though, if I was to do a gearbox reset, will this affect the remap?
  14. John Laidlaw
    John Laidlaw Senior Member
    15,933
    3,566
    Nov 15, 2013
    Wirral
    Your Mercedes:
    W212 E63 ///AMG V8 Biturbo Volvo XC90 2018
    You mean an adaptive reset? If so no I shouldn’t think so but check with the folks who did the map to be certain
  15. LostKiwi
    13,788
    5,211
    Aug 25, 2006
    Your Mercedes:
    A proper remap will always be better than an add-on box.
    A gearbox reset will not affect the map.
  16. Westheath
    1,299
    372
    Nov 6, 2015
    South London
    Your Mercedes:
  17. V6Matty
    V6Matty Senior Member
    5,303
    419
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    As above the 270 responds well to a remap, and yep the adaption reset doesn't make any difference to the map
  18. OP
    dubburke
    40
    Dec 20, 2014
    N.ireland
    Your Mercedes:
    mercedes c270 cdi
    Can anyone recommend an upgraded intercooler, that will fit with a minimum of modification, also, do the 320cdi in line injectors flow more fuel than the 270 cdi ones?
    I have bought the larger 320 cdi turbo from ebay, and is away for a overhaul, what boost can this turbo manage without issues on a daily basis?
  19. oigle
    oigle Senior Member
    2,779
    137
    Mar 15, 2005
    Your Mercedes:
    Currently 2003 ML270. 2012 Nissan Maxima 250SL.
    Welcome to the world of turbo lag. Turbos are sized for a reason. If you are only going to live at high revs, fine. Normal driving and very laggy.
  20. umblecumbuz
    umblecumbuz Senior Member
    3,101
    522
    Sep 20, 2010
    Wales and Gozo
    Your Mercedes:
    S204 and CLC 204 cdi, other non-Merc machines
    And I always thought my 270 with a remap was fast enough and totally trouble-free, apart from the occasional leaking injector seal.
    They were a real torquey engine with excellent economy.
    Miss mine
    oigle likes this.
Share This Page
